Inside the Cheapo Quick-Change Toolpost
Identified by
@Nogoingback and
@DavidR8 as "Dickson type"
The smaller pictures are thumbnails of 1280 x 720, some of them cropped a little.
Here is where we get down and dirty into the very insides of the
RDG Toolpost. From the outside, it is pretty business-like, and the basic design principle seems so effective that it has to be competitive with any other, be it wedge, piston, Aloris, or one of those Chinese that comes as six digits like "250-111" or something. The main post and the tool holders are very hard, and all ground. The clamp and it's crank are softer, and maybe they are supposed to be that way.
Start with one of the eccentric crank and clamp lifted out.
__ __
The working principle is seen. The amount of eccentricity is small, so even rotating the clamp only with fingers pulls it up pretty hard.
Let's get a close-up of the hardened insides. A wipe with a PT did bring up some black, but I think it was mostly Moly grease.
A close-up detail of the clamp part shows the export mass-manufacture finish. I do hope it was not from some semi-starved urchin with an old lathe, a hand drill, and a file! I made the images 1280 x 720, then cropped some. The flash on some gives the critical harsh light that shows up all the scratches.
_ _ _
The close-up of the main operating part clearly shows how it works. That offset crank pulls on the piston-like clamp, though I don't think this is the same thing as is meant by "Aloris piston-type". I just don't know.
Here is a close-up of the eccentric crank.
I think the crank is harder than any old bright steel, but it is not as hard as the post and holders. I tried scratching it with a screwdriver, and not much happened. It does yield to a file. The turned finish on the eccentric offset is nothing to write home about, but it does "work, and for the most part, I guess nobody gets to see it unless they took it apart.
Two kinds of lighting. Amazing. Just about the harshest, most critical one can get!
_ _ _ _
The Hardened Burr from Hell!
It bothered me some that the crank rod would get it's turned ends somewhat scratched up in removing it, and trying to put it back. It was a hardened burr. I resorted to a diamond thing in a die grinder.
_ _ _
The last two pictures makes it clear exactly how this works. The operation is exactly as
@RJSakowski explained.
_ _ _
So there it is. For
£125.00 I was expecting something worse - possibly even to the extent of regrets, and accepting that if you buy trash, you buy twice. That turns out not to be the case. Internally, it won't win any beauty contests, but there is no question that it works really well.
I am not too worried that various makers will use the Dixon style, but vary the width to make them "incompatible". Separate toolholders are available now. I think this particular Boxford/South Bend compatible style is likely to have toolholders available into the future, but for me, I do not anticipate buying a whole big set. When I am ready to do that, I will have researched QCTP's, their toolholders, and all that goes with them
You will know that I fumbled when you see another posting like this, except Aloris or A.N.Other as the victim!
