EvaporustWhat did you use to clean with? That stuff looks nice and shiny...
that's why I recommend the silver tarnish felt. A little more but no side effects. And I've never had rust so it's doing it's job of keeping oxidation at bay. Get some evapo rust, or use oil and fine steel wool.Tacky Glue
And contact cement - don’t need 100% coverage on the felt, just enough to keep it from sliding around).that's why I recommend the silver tarnish felt. A little more but no side effects. And I've never had rust so it's doing it's job of keeping oxidation at bay. Get some evapo rust, or use oil and fine steel wool.
What Did You Buy Today?
The big girl is finally home, just need a nice cool day to move everything parked in the front of the shop into its final location.www.hobby-machinist.com
applying contact cement from a can is tough on any felt.. spray contact works just to add info. And it only requires a dusting.... but again, that's why I like the self stick.. it's easy. I think @wachuko liked it as well...And contact cement - don’t need 100% coverage on the felt, just enough to keep it from sliding around).
It shouldn't, and didn't seem to. The manufacturer states that evaporust will only react to the rust and not the base metal no matter how long its left in the solution.Will soaking your end mills and drills in Evaporust dull the sharp cutting edge?
Roger L
Roger L
