- Jan 2, 2019
- 6,543
We use 1" PVC to move full safes. Once you have the first piece under the thing you are moving the rest is pretty easy. For a lathe you can use a floor jack to lift each end enough to get the pipe under. With a safe it is a bit more complicated but they can usually be tipped by a couple guys. The weight is spread over the length of the pipe and divided by the number of pipes you have under the thing you are moving. You would be amazed at the ease of moving an object that way, in fact take it very slow as getting it moving is easier than stopping it.
Safes full of ????
Are these your safes, or "borrowed"
