- Dec 12, 2016
- 497
Another thing on L00 back plates and chucks...
You will need to consider where the chuck mounting screws are and if they would interfere with the retaining thread/ring that holds the mount on the lathe. Depending on the situation it may be better to have the bolts coming in from one side or the other, and some will just not work at out all. Look carefully at the mounting bolt circle and how that compares to the mounting plate and make sure they will be compatible.
