Large work on a Bridgeport
ttabbal
Jun 12, 2017
2,094
I got a spacer for it. It fits great on the column, but the turret is a few thou too big. I was thinking of clamping it to the table and boring it out a little. I figured I should ask here in case I might have missed something and to get tips for the setup. I tried lining it up with the long bolts it came with and getting it as straight as possible. No dice. It's not off much, but I don't have a caliper or mic big enough to measure it properly. It's close enough I suspect I could pull it in with the bolts, but I would rather not have it press fit on there.
So I thought I'd clamp it down, or if it will fit, use the vise. Then use the Criterion boring head with a bar in the side mount. That would have a little over 6" from the spindle. Seems like a fair bit of stick out, but it is a light cut.
Another option is to use a rotary table. Mine is pretty small, 6" I believe. So I could mount a plate to it, clamp the spacer to the plate, and use a normal milling cutter on the ID.
My lathe is a PM1127, so I can't chuck it up on there.. :)
Clamping it down to the table makes the most sense. The boring bar sounds good, but run slow. As I recall a BP is 80 RPM minimum unless you have a VFD. 80 RPM might be a bit fast at that diameter.
With a carbide tool, 80 rpm should be OK for a light cut. Be nice if you could borrow a vernier caliper to check the sizes.
I do have a VFD. Not sure how low it can go. I have insert boring bars. I'll probably need them as I don't think my cobalt bars are long enough to reach. I plan to run slow, both for SFPM and vibration. I've never done anything quite like this, so it should be interesting.
After much cursing at my garbage indicol clone, I have it centered. I could probably give it a go if I owned a left hand boring bar. *facepalm*
Maybe if I bore up? o_O
It looks a bit high on the pucker factor to have that bar acting like a propeller, but it feels sturdy when the boring head locks are set.
Yikes!
Hitting to go button on setup would be terrifying!
Yeah. I kind of like the idea of going from the bottom. The spinny bits will be enclosed in cast iron when starting up! :)
I am a complete beginner, when it comes to machining. I am NOT a complete beginner when it comes to breaking tools or machinery.
That pic scares the crap outta me.
It feels like a bit much. I'm not sure what would be better though. I haven't fired it up, still thinking about options.
Making note of the machinist term “spinny bits”
