- Jun 10, 2019
- 534
I feel like every time I run a larger endmill (5/8"-3/4"): it inevitably will start pulling out of the R8 collet. My most recent case was side-milling 2" thick steel. Endmill this time was a 3/4" YG rougher 3" long. I was running a 0.200" RDOC, 230RPM, 1.5IPM. These might be somewhat conservative numbers; FSWizard suggested 560RPM and 3.5IPM -> fz 0.0016in/th (my numbers have the same chip load). The milling is on a Alliant knee mill. The milling otherwise went perfectly fine; machine wasn't straining at all, chips looked great.
I tried 2 different collets (one was brand new Shars "precision" collet); both behaved the same. This has happened both when manually torquing the DB or with my power drawbar. I run my power drawbar at 90 psi (op range is 80-100psi) and the mfr recommends impacting for 3sec once collet is seated. I typically let it dwell for 1.5-2sec. I did test at 100psi and 3sec; no help. Interestingly, at one point this wedged the collet in tight enough that the power drawbar couldn't push the collet out. Instead it sheared off the threads on the drawbar. I had to give the EM a tap sideways to dislodge it. It was not caused by the alignment pin jacking up the slot in the collet...the collet simply was wedged in there that tight.
The bore in the spindle feels fine; no burrs or dings. But I haven't tried bluing it.
Am I expecting too much or should this type of cut / load not be pulling the EM out? Anything else I can try?
I realize I could use a ER or Weldon type adapter, but was avoiding adding length and potential runout to the setup. I did eventually swap to the ER40 and no sliding issues there.
