- Jun 10, 2019
- 534
Agreed that Weldon & ER40 are going to grip tighter. But...is it possible in an R8 w/o slipping or no? If y'all's suggestions are implying that it isn't possible: that's fine; I'll know never to attempt it again
Same here. Tightened either by hand or the power draw bar. I run my drawbar at 80 psi, and don't let it hammer even close to the count of three. Zero slippage on end mills up to 3/4". May want to blue up a collet and see if you have good mating contact with the spindle.In 48 years I've never had an end mill slip in a collet and I've pushed them to the limit . Just have to make sure they cut and not rub .
Ive done some pretty ignorant things in my years, but having anything other than a carbide endmill move in an R8 is a rarity for me.Agreed that Weldon & ER40 are going to grip tighter. But...is it possible in an R8 w/o slipping or no? If y'all's suggestions are implying that it isn't possible: that's fine; I'll know never to attempt it again
OK, sounds like it should work fine. Bluing up might be in order; maybe buy a quality collet.
Any other thoughts about F&S? I think I was in the ballpark of FSW's recommended chip load (fz 0.0014); just had the feed & RPM dialed down accordingly. I was a bit hesitant to run at the #'s FSW was suggested. What would you guys suggest?
To be precise about what is happening: the EM slowly (over the course of the cut) creeps out. It never stalls or spins in place. In this project: maybe crept out a total of 3/8"-1/2" over a 6" long side milling cut. Mill has a Prototrak a 2-axis control and ball screws. Same thing happens conventional and climb milling.
Longest book I have ever read. " Endmills slipping out of R8 collets. Use ER or the grub screw holders. Or..... .....gamble ???
Yep, aware that quill stick-out can affect milling due to rigidity / runout. Due to the machining ops being CNC-ish the EM started over the workpiece. For the other side I started the program at the side-milling portion only and so I could choke up on the quill. The knee doesn't have a readout so I can't easily incorporate into the ops. FWIW: didn't seem affect finish, but point is certainly valid.Also, all that stick out on your quill is not helping anything and generally bad for your machine.
