[4]
Lathe broach...old concept......my style
[3]
[10] Like what you see?
Suzuki4evr
Active Member
Sep 29, 2017
469
Likes
467
#1
I am posting this in this room,but it is not a project of the day but rather days.
When it comes to keyway broaching in the lathe I usually had a bit of a sigh on on my face, because I am not a big fan of moving the carriage back and forth all the time and a specially when doing keyways in taper bores. Those I am not a fan of at all. I don't think the compound rest screw was designed to take so much force for broaching. Sooooo lets make a broaching tool. I've been wanting to for a while now and a job came in wich required blind 8mm keyways.
I made a lathe drill holder a short while ago so I thought I am going to modify it so I can use it for this purpose aswell.
I just had to mill out a section for a the hinge mechanism and I made two bushes out of teflon,wich is fine for this in my opinion.
I guess I could have made this much simpler,but I wanted it nice......that's just me.
This is the hinge parts. Forgot to take pics of the manufacturing process.
I must say my new Vertex BS-0 dividing head came in pretty handy on this project,I just got it in time.
I made a nice strong broaching arm with a fine knurled handle section on it.
The broach rod has a removable part in front for different size bores and key sizes.
I realised how important the broach tool form actually is. This shape worked best for me.
The final product and it works pretty well.
Thanks for watching
Michael
benmychree
John York
Jun 7, 2013
2,751
Likes
1,992
#2
I'd think that the cutter pictured has too much front clearance, and might tend to hog in.
MAKEITOUTOFWOOD
H-M Supporter - Silver Member
Dec 3, 2016
294
Likes
480
#4
Very cool. Thanks for posting.
woodchucker
Bronze
Nov 25, 2015
1,504
Likes
1,041
#5
That's a lot of overhang off your toolpost. Does it flex much?
rgray
Nov 26, 2012
1,062
Likes
558
#6
I think I have seen a version like that with a vertical handle.
That horizontal handle looks much more user friendly.
Suzuki4evr
Active Member
Sep 29, 2017
469
Likes
467
#7
Are saying that the toolbit will dig into the workpiece. I did not see that happening,the tool was rather tending to push away from the material a little bit because of the bar diameter. I played around with the toolform and kind of copied a broach I have and this form worked well.
Suzuki4evr
Active Member
Sep 29, 2017
469
Likes
467
#8
S
Thanks for sharing!
It looks great.
-brino
Sorry Brino,"SHARING". I don't know what is going on with me these days, it seems I am on a roll with bad spelling and wrong words lately. Must be getting old it seems.
Suzuki4evr
Active Member
Sep 29, 2017
469
Likes
467
#9
No
Hallo Woodchucker.No, it is a real sturdy setup. I think the pic doesn't do it justice.When I made the holder originally as a lathe drill holder I actually did want to make to fit directly onto the QCTP,but a combination of lack of time and a bit of urgency forced me to make it as quick as possible.
Suzuki4evr
Active Member
Sep 29, 2017
469
Likes
467
#10
It works quite smooth, but in afterthought, I wish I made the handle a few inches longer just to get a bit MORE leverage, but I made the measurements up as I went along. Last knight I had an idea to mechanise it by removing the hinge section and handle completely and installing a low RPM high torqe motor of somekind with a centrifugal bush and rod on it and then my bad sholder won't have to do all the hard work anymore. If someone has an idea of what kind of motor I can use it would be greate. I thought of using a wiper motor seeing that you can use it to make mill bed autofeed mechanisms,but i am not sure if the torque would be sufficient. Maybe someone can advise me on this.
brino
Jan 2, 2014
3,461
Likes
3,487
#11
an automotive door window drive motor would probably have more torque.
-brino
[6]
[5] [7]
