- Dec 23, 2020
- 59
I'm reassembling the gearbox on my Samson (Tida) lathe.
I see four different types of areas to lubricate:
1. Shafts where they rotate on the gearbox case. These have oiling holes. The Tida manual calls for 160 SSU which I've not been able to correlate to a consumer designation. The Grizzly manual (for a later version of the same lathe) calls for ISO 68. And, I read another thread here arguing for ISO 32 which I was able to get locally. Should be OK or should I get ISO 68/something else?
2. The gears themselves. No sign of oiling holes/paths except one side of the shaft with the change gears which has a spiral oil galley. The others are smooth shafts. Like above, the TIda manual calls for SSU 160 for the gearbox generically. The Grizzly manual calls for ISO 68 for the gearbox generically but shows oil plugs which my lathe does not have. I read somewhere a recommendation for grease on the gears but can't find that reference now. I do not see how oil would get on the gears from the oil holes going to the shafts other than what works its way past the shafts. Any ideas how the gears should be lubricated? And with what? Once bolted to the lathe bed, access to the gears is limited.
3. Thrust bearings. Two sets on the outside of the case where there are couplers going to the lead screw and carriage drive. One set is inside the case on the lead screw shaft. ISO 68 oil?
4. Roller bearings - two roller bearings on the shaft with the gear selector handles. Should these be packed with grease? Or should I use the same ISO 68?
