- Jun 12, 2014
- 4,817
Purchased my inserts from Zoro's when they were a bit cheaper, their prices have gone up significantly. Least expensive option is to purchase directly from Carmex, see links below. I also have some Mitsubishi MMT16IRAG60-S VP15TF 16IR AG60 threading inserts but haven't used those yet.
The Carmex inserts I am using do not have the B chip breaker, they come w/wo this specification. I probably would go with a chip breaker if reordering. You could also speak to Carmex technical if you have specific questions about which insert they recommend for your application.
Carmex Threading Inserts Product Specifications
Insert IC 3/8"
Chipbreaker B
Pitch Range_TPI 8-48
Pitch Type AG60
Grade BMA
Brand CARMEX
Profile Type Partial Profile
Coating PVD / TiAlN
Designation 16 IR B AG60 BMA
Insert # 16 IR B AG60
ISO K CAST IRON X
ISO M STAINLESS STEELS X
ISO P STEEL X
ISO S HRSA EXOTIC X
CARMEX - 16 ER B AG60 BMA / Indexable Threading Insert / AG60 Pitch / 8-48 TPI / External / Right Hand
Mfr #: 16 ER AG60 BMA
CARMEX - 16 IR B AG60 BMA / Indexable Threading Insert / AG60 Pitch / 8-48 TPI / Internal / Right Hand
Mfr #: 16 IR AG60 BMA
CARMEX - 16 IL B AG60 BMA / Indexable Threading Insert / AG60 Pitch / 8-48 TPI / Internal / Let Hand
Carmex does have dual sided laydown threading inserts, but require a different holder and anvil, they are only available in 3/4" and 1" insert holders.
List of all available size 16 partial AG60 profile Carmex inserts:
Insert IC 3/8"
Chipbreaker B
Pitch Type AG60
Grade BMA
Brand CARMEX
Coating PVD / TiAlN
ISO K CAST IRON X
ISO P STEEL X
ISO S HRSA EXOTIC X
CARMEX 16ERBAG60BMA - 16 ER B AG60 BMA, Indexable Carbide Lay Down Threading Insert, AG60, AG60 TPI, External, Right Hand
Carbide Threading Inserts from Carmex for External & Internal Applications. Presenting here is the wide range of V Partial Profile 60° carbide threading inserts that offers high productivity for many materials and applications. You can select from a large assortments of inserts grade and...
www.travers.com
CARMEX 16IRBAG60BMA - 16 IR B AG60 BMA, Indexable Carbide Lay Down Threading Insert, AG60, AG60 TPI, Internal, Right Hand
www.travers.com
