I asked this question in the Jet specific forum but think it would do better here. My back doesn't allow me to bend over much and I want to raise the lathe up about 10" to put it at a comfortable standing height. Has anyone done something like this and how did you do it? I will be setting the lathe up in a temporary location, temporary could be a couple years, so a permanent set up isn't called for yet... I think for the permanent solution I want to pour a raised concrete pad for it to sit on with anchors cast in to bolt it down to.
Maybe that would be the best temporary solution as well if I put some plastic down so the slab could be removed later.
any thoughts?
Oh it's a JET URPE 1440 that weighs in at 2500 Lbs.
Thanks
Brian
any thoughts?
Thanks
Brian
