- Nov 16, 2014
- 56
Hi guys.
I have an 04TLC-700 with a broken bearing support on the countershaft bracket. A prior owner made a temporary repair with a bolted-on doubler over the break.
I'd like to make a more permanent repair, but I haven't been able to find another countershaft bracket (LA-302). So I'm contemplating fabricating one. Here is a sketch of a couple of options using pillow blocks for the countershaft bearings.
![countershaft compare.jpg countershaft compare.jpg](https://www.hobby-machinist.com/data/attachments/52/52130-aa0c3011fac482658567674257bfd3d5.jpg)
The one on the left looks more like the OEM part, but I feel the one on the right would be easier to fabricate.
I'd welcome some comments on this approach, and I wonder if someone can tell me how critical the alignment is for the flat belt pulleys.
I can make adjustments with shims and slotted mounting holes, but I'm wondering if there's a need for some kind of screw adjustment, similar to the OEM setup.
![bad countershaft.JPG bad countershaft.JPG](https://www.hobby-machinist.com/data/attachments/52/52131-fe2dba390907d4b61b7a48095b5c8c84.jpg)
Thanks in advance for any feedback.
regards,
Leon
![temp_repair.jpg temp_repair.jpg](https://www.hobby-machinist.com/data/attachments/52/52128-a4abcf434e21fe443fa563d699398965.jpg)
regards,
Leon
