Hello i was wondering if someone who has a logan 10" lathe could post a picture of how the drivebox is connected to the headstock. I am missing the parts. Thanks.
My Logan 820 was apparently somewhat modified in this drivebox/headstock connection, but these photos shows the bracket that should have rubber bushings that take pin from the drive box. Photos 2 & 3 shows mine had that aluminum shaft and no vibration isolating bushings.
Anyone know if a 820 and 200 headstock casting are the same? I dont see hole to bolt anything to on the back chuck side. I could not find a countershaft correct for my lathe, so i was going to convert to the more readily available 820 style.
This is from the 800 series but the 200 is very similar. Part number LA-658 is a rubber bushing. Set screw 0441 holds pin LA-399 in place. The rubber bushing is held captive between bracket LA-657 and the frame. The rubber bushing LA-658 is available from Logan https://store.lathe.com/headstock.html I believe there were several different headstock casting part numbers used for both the 200 and 820 depending on serial numbers.
