- Nov 9, 2015
- 407
I'll voice a rather unpopular opinion.
I would suggest you look for a used Smithy 3 in 1 machine, preferably the Granite 1324. This is a great machine if If you're space limited, and are sure you will not need a mill that requires tight rigidity and a lot of travel.
I've had a Smithy Granite 1324 for a long time and eventually acquired separate lathes and a BP clone. But I kept the Granite, and use that lathe much more often than the others. But I haven't used the Smithy mill in a long time.
- The lathe is good, and can be made very good by adding a QCTP, solid toolpost, and an inexpensive DRO, such as an Igaging set-up. Plus a stout, well made bench that is firmly secured to minimize vibration and allow for bed leveling would be a must
- The mill is limited in travel, especially in the Z. But like any machine, you would know this going in, and would also realize your depth of cut would be limited
- Smithy has a pretty good reputation, and their customer support is excellent
