- Sep 23, 2020
- 80
I previously bought stuff to make a cnc but the project became more than i could chew. So I'm after something that's ready to go that i can learn on. End goal is to use it for 4th axis work. Prefer it to be small and rigid.
I realise I'm likely to be directed to go with brand names and make my own, change the control box etc.... I just want something to get started on.
Something like this would be ideal if I could mount a 4th axis to it but i don't think there is enough space to mount the 4th axis - High Strength Steel 2030 400W DC Desktop CNC Router Engraver Machine AC110V/220V | eBay It has fixed rails and fixed gantry so should be relatively rigid for a small machine. And of course it's pretty cheap.
The next step up that i might consider is a big jump in price - Linear Guide Rails 1.5KW 2.2KW 4 Axis CNC Router MACH3 USB 3040 Metal Aluminum Iron Steel Engraving Milling Machine|Wood Routers| - AliExpress
If i'm going to pay that much i might as well get a reliable brand right? is stylecnc reliable? Desktop CNC Router with 4th Axis Rotary Table - CNC Wood Router (stylecnc.com)
For that money i could get something more rigid - 1.5KW 2.2KW 3.5KW Full Cast Iron CNC Engraving Machine 3040 CNC Router Metal Milling Machine Z Axis 170mm 220V|Wood Routers| - AliExpress
This one looks almost purpose built for what i want but i wonder about rigidity - Cylinder CNC Router | 3D Carving Machine – NRY CNC Wood Carving Machines (bravoprodigy.com)
It's a good bit of $$$ so i'm hesitant to jump. Any suggestions or experience with the above machines?
