- May 3, 2020
- 229
Thinking about a good-enough assortment for a fairly serious hobby shop or small prototype shop. What to include?
So far, I've just purchased what I need. But waiting is really killing my momentum. Also, I don't have everything organized so I sometimes re-order. Also, there's nothing compelling me to compromise so I end up with oddball stuff that's not always usable for other projects.
I can't stock all the things but I do want access to most of the sizes, coarse and fine, metric and imperial. I'm sure I need socket-head cap screws but probably round and flat head, too. Mainly I need black oxide alloy screws but maybe stainless, too.
I've looked into existing assortments. Often the price is good but you end up with a lot of lengths and not very much variety in screw size. That's nice but I can cut a screw to length in the lathe (or with a hack saw) easily so I don't need the convenience. I'm thinking have 2 lengths of each screw: 4 x Diameter and 8 x Diameter. That narrows down on the selection.
For the more experience people on the forum---am I missing anything or including too much? What is your ideal fastener selection, if you had some money burning a hole in your pocket?
To illustrate the idea, I put together an assortment of socket-head cap screws in black oxide, imperial (below). I took some liberty with the lengths. For some lengths, they're just really expensive. Probably just oddball lengths. The selector columns are just to remove certain things from the price total. The price/screw column is colored based on price---more red means more expensive.
It's a fine selection but the total price is a lot. If I could split that with someone... Obviously the 1s and 5s can't be split so the total price of a combined order would be a little higher.
