- May 3, 2017
- 1,997
If I turn a long piece of stock (aluminum or mild steel) using the three-jaw chuck and the tail stock, I get a slight but consistent taper, so I'm pretty confident my lathe needs to be aligned. I have a 36" by 1 1/4" piece of tool steel that I want to use to make a test bar, but before butchering anything, I have a few questions:
1. I'm assuming I should align between the three-jaw chuck and the tail stock. Right/wrong? (The chuck is a Bison that I bought new. It's in very good condition.)
2. My lathe is an OTMT 13 x 40 (looks almost identical to the PM1236 but larger capacity). How long should I make the test bar?
3. What's the best way to cut it?
a. Lathe? I have an Aloris BXA tool post with a Kennemetal 'EVSCTR120326C' cutoff toolholder that can easily handle the diameter but I am uncertain about the hardness.
b. Band saw? I have a horizontal band saw. Same issue regarding hardness.
c. A better way?
3. Is it necessary to cut it at all? 36" is pretty long. Should I be nervous about trying to face and center drill with that much length hanging out the back - even if supported? It'd be nice to keep it intact, but I don't mind cutting it if necessary.
4. Any other tips I should know before wrecking a nice piece of tool steel?
Thanks for any advice.
Regards,
Terry
c. A better way?
Regards,
Terry
