- Sep 19, 2019
- 109
Well there seems to be many trains of thought along this line. I can only tell you what worked for me.
Number ONE! Get it level. With a good level, your 6" torpedo won't do it this time, spend a few bucks or borrow one. No Twist, no Cant. Full length check along and across the ways, as many directions as you can figure a way to check it. And make notes, gives you something to look at to see if you're making a difference, I tend to forget, notes and sketches are easy. Take your time, let it settle for a few days between leveling sessions, mine took 2 months to get & keep level. Cast iron doesn't move easy or fast.
I wouldn't cut that piece of rod. Just face it off & center drill both ends, that way you can check alignment at several points along the travel of the tail stock. After you face & center drill it mark it lengthways with something to align with a chuck jaw with something semi-permanent, that way it'll be semi-repeatable and you can move it (longer or shorter). You don't need to make any cuts on the rod, a couple of dial indicators (tenths if you've got them), one for a top reading, one for the front, set up on the Tool-post with a couple of Mag-bases. Just keep running the carriage back & forth and making adjustments on the Tailstock until it's Dead-Nuts. And remember vertical alignment will cut a taper as well as side to side.
I know it sounds like a pain but, I've got my tailstock to less than a tenth front to back all along it's 36" of travel, I'm still off a touch in height, I'll get that straight as soon as I can get the tailstock split & shimmed.
Before you start, be warned, this Rabbit hole goes deep, there's no sense stirring a pot of worms if you're happy with things as they are! Why spend months chasing 0.002" of taper along 3' of travel when most of your work is only 10 to 12" long?
