Another design here. http://www.innovativetoolsales.com/Skoda Centers 2013 Brochure.pdf
Quite different from the Royal.
That's a little fuzzy, but I can kinda make out dimensions.I found this is another site.
A good way to find relatively inexpensive high grade bearings for our projects is to try to find some that are made in large production runs for use in common consumer goods, like automobiles. It pays (literally) to start your search in that way. Another way is to look at surplus sources, if you can buy spares at the same time or don't think you will ever need a replacement. Sometimes there are real deals on stuff that will fit obsolete high grade military stuff. Just do not plan on ever finding them again.I've done some quick searches on Amazon and am surprised at the cost of the bearings.
The body-turns feature means you can finish-grind the point while driving the body with a rubberTake a look at this design. It is the cheap Royal center. Anyone have an idea of the bearings used? Interesting in that the entire body turns.
http://www.royalproducts.com/content/files/products/Value_Turn_LC.pdf
