Again ignore the mess in the back ground here is another shot as to how nice the blocks to align the fin up. The motor will bolt up to the far end with a shaft coupler the mount that hangs down has a hole drilled in it and fastens to the motor mount I made for the boat.
Here I cut threads in a 3/4 X 6' stressproof shaft the left hand grooves are cut to keep crap out of the seals it is suppose to push it out instead of pulling it in.
