- Mar 26, 2018
- 8,412
Hi,
I am not new to band saws but this old saw is in the middle of a refurbish for personal use. I love the old iron.
I was cutting a piece of cold rolled 2X2 square stock last night. This is the first time I have used this saw. Plenty of lubrication.
The hydraulic lowering valve is not sensitive enough (will be replacing it) so I had to lower the blade manually. It cut very fast and smooth with one big problem. The cut was angled a bit, dished out if that makes sense.
I have the roller/bearings fairly snug on the blade so I am thinking I had too much downward pressure causing the blade deflection?
Does this sound right?
I'll go back and check the adjustment of the concentric gadget.
This blade came with the saw, it's old but seems to cut well.
Could it be the blade?
I know if a chain saw blade gets dull it will dish out.
Thank you for your ideas.
Jeff
Jeff
