Somehow even a simple thing like a hinge can get out of hand.
Functionally it can lift the lid and then rotate it out of the way.
Added a little extension to the lid, both for looks and to lessen twisting force on the joint between handle and lid.
Finished welding it and then blending everything, literally hours of work just there.
Quick mockup roughly how it's going to sit.
Aaand lots of hours here as well somehow.
Square tube was just drilling some holes, fast.
Bottom left was a 40mm hot rolled bar, milled flats so it'd fit in the square tube, cleaned everything up and bored it out for the shaft on the right.
Also added the little "roofwasher" from some other junkpiece.
Couple of hours getting all that done and the fits right.
Bottom right piece was a 60mm chunk of alu bar and 25mm steel rod. "Lathed" and polished part of the steel rod to fit in the left piece.
Squared up the alu piece, bored it out for a pressfit for the steel rod and then some hours in the mill, making the shape up as I went.
I'm pretty bad at "making things up as I go" so I'm trying to get more practice doing that, instead of spending hours in 3D-CAD.
