- Jun 12, 2014
- 4,848
If you need a specific odd tap/die you are much better off getting a mainstream manufacturer either through a supplier or check eBay. I have a number of Toolmex Dies and YG taps purchased through Suncoast, they have all performed quite well. There is a wide range of manufactures, styles and coatings. Prices for 9 mm start at around $6. I get HSS taps and dies vs the lower quality/performance carbon steel. As far as sets, pretty disappointing as to and decent set that is under $400, I have a Snap-on set that I used for years, but for the most part I buy tap sets (taper plug, bottoming) for the most frequent used taps and have boxes of adjustable round dies. I buy individual ones as needed for a particular project if it is an uncommon size, or cut the thread on the lathe.
M9 taps and dies from Suncoast Tools
This is just one draw, I keep spiral taps in another draw as well and other tap and die holders. Imperial is on the left, metric on the right bottom, plus those in the Snap-on case.
Product Search | Suncoast Precision Tools (SPT)
www.suncoasttools.com
