- Nov 5, 2016
- 1,419
The way I treat those speed and feed charts/formulas is they are set up for very good conditions (machine, cutter, workpiece, etc) and the maximum you can use. I don't run things that high on my machines and I would guess, as a general rule, I use 60-80% of those recommendations.
Especially for import cutters. Even in mild steel I've found when I use a 1/2" HSS import end mill I run it maybe 350-400 RPM for roughing. They just don't hold up like the better cutters.
Ted
Ted
