- Apr 8, 2021
- 138
Hello.
I have a minimill. Is a chinese weiss 18vm. Its configuration is very similar to a precision matthews, but smaller, it weights 133 LBS while the precision matthews weights 340 lbs.
The question is it vibrates a lot. Sometime ago in other forum I asked about that because I was using a face mill (2 inches) and that could be so big for that machine, but now I´m using a HSS TiN coated 10mm 2 flute end mill in aluminium and it is the same. I tried at 1.000, 1500 and 1.900 rpm and it vibrates a lot. The deep of cut is 3 mm and no matter the feed rate. Even at 0,3mm per second feed rate.
I lock all the slides, I tight every scree I can, except of course ones I need to move the table. The mill is firmly bolted to the table and I have put a thick layer of dense rubber between the milling machine an the table to try to avoid vibration.
I leave you a video.
Is that normal? I know is a 1.300 USD chinese machine, but I don´t know if it is normal so much vibration
Thank you
best regards
Thank you
best regards
