Hi, Eric.
If you don't need a big machine, you might want to see if you can find the August 1969 issue of Model Railroader magazine. Ben King had an article on how to build a neat little sensitive drill press. It stands about 7" tall and the base plate is 4 1/2" deep. Of course you could scale it up if so desired. It is largely made of brass and a few bits of nylon and a bunch of small machine screws. Quite a simple design and it should be fairly easy to scale it up if required.
In the January 1970 issue he followed up with a belt drive for it. The problem is that the original design called for a specific surplus motor that was not widely available even then. The belt was just an O-ring. He drilled .004" holes so it should have adequate precision for your needs as long as the overall size is right.
I started it a number of years a go but like so many projects, life got in the way and I have never gotten around to finishing it up. I made the column higher and the base plate bigger. I hope it goes better for you.
Al
Al
