Mobile work table
Batmanacw
Sep 3, 2020
1,437
I intended to turn this cart into a welding table but lately I've needed a work table more than anything. A good friend gave this cart a while back.
I made the frame a slip fit.
I used two layers of sanded 1/2" plywood.
It still fits under my bench!
The wheels don't lock so it's not ideal but I'm going to make a couple front/back chocks so it won't roll too easily.
I do not want to cut off the old wheels and try to weld on locking casters. It's good enough the way it is.
I pounded on the top with a 2 lb dead blow and it's solid. It's going to be so nice....
Looks good. And the best thing you can do is to always put it back under that work bench when not in use. Otherwise it will become afflicted with EFSS (empty flat surface syndrome) :)
Ted
