how important is the angle of the rake (back, front and side). as a novice tool sharpener i would think that it is not very important but, what do i know. if it does matter; what will more or less angle do??
Rake angles. The rake-angle combination varies greatly according totool material, workpiece material, and cost. Thermally efficient cutting is improved with positive rake angles or at least positive rakeangles with respect to chip flow or true rake. It should be understoodthat a high positive rake results in a more fragile cutting edge andoften must be compromised for tool durability. As cutting speedsincrease, the rake angle has less effect on tool pressures.Therefore,in using tool materials that can be operated at higher cutting speeds, it becomes possible to use less positive rake angles or even negativerakes to increase tool strength and economize on tool maintenance.
Prismatic-insert and throwaway-insert tools are greatly simplified inuse and maintenance by using negative rake angles, although more
cutting power and increased cutting forces are required.Combining negative back rake with positive side rake allowssafer cutting through slots or keyways, thus placing the initial
impact loads on a portion of the cutting edge removed from the noseof the tool bit.
The cutting radius is dependent on the speed and feed rate. A rule of thumb is that it should be a minimum of 1-1/2 times the tool moves for each revolution of the spindle. An example would be that if the tool moves .004" for each revolution of the spindle (chuck) the radius on the tool nose should be a minimum of .006". The larger the radius the more material can be removed per revolution. The smaller the radius (keeping the minimum in mind) the better the finish.OK; the above helps. next question. sharp cutting point vs. a radius??
