- Feb 28, 2019
- 504
Be aware that the lathe may be limited by size and power as to how much of cutting radius you actually use. Just imagine trying to push the a full 1/4" or even 1/8" radius through a cut with a small lathe. The point is that you can't use the full radius and hence all the effort to getting the other angles won't matter much if you only cut with the radius.
Generally radius on small lathes are going to work better if smaller (if you want't actually cut with the sides)
