- Jun 12, 2018
- 712
I have a small 1HP pool motor that has a shaft that's damaged. It's about .600 in diameter and about 16" in length
I plan on TIG welding the gouges on the shaft, then turning on my lathe down to its proper diameter. The main part I need repaired is where the bearing is pressed into. I guess the other areas don't matter too much.
Do you think it's safe to do so? I'm worried about warping the shaft with the heat due to it being on the thinner side.
