Looks like there is room for a hook pin spanner hole, (just in case).Finished the draw bar:
And the baby Bison has about .0005 TIR!
You need to be giving me this advice BEFORE you know I am about to make a mistake. This is how a lot of mini-lathes are set up. I was hoping to get really good spindle alignment which I did. Apparently there is a lot of flex in this setup causing chatter. It's a mistake I will learn from. The D1-3 back plate is an option because the chuck has 3 mounting holes (4 would be a problem since the bolt hole circles are almost the same.) This approach was less expensive, or so I thought. I did not foresee this issue or I would not have gone this route.I wouldn't recommend hanging a chuck on a MT3 the way you have it, I would expect there would be flex and movement under lateral load when cutting. Not sure why you didn't use a D1-3 back plate to mount the chuck.
Try something other than brass.You need to be giving me this advice BEFROE you know I am about to make a mistake. This is how a lot of mini-lathes are set up. I was hoping to get really good spindle alignment which I did. Apparently there is a lot of flex in this setup causing chatter. It's a mistake I will learn from. The D1-3 back plate is an option because the chuck has 3 mounting holes (4 would be a problem since the bolt hole circles are almost the same.) This approach was less expensive, or so I thought. I did not foresee this issue or I would not have gone this route.
I could keep this as is and use it for precise small diameter work. Not sure what I'll do yet.
