- Nov 23, 2017
- 1,191
Spin the grinding wheel by hand and then turn on the power while it spinning.... If the motor fires up and runs then you need capacitors..... If it doesn't run like that then scrap it....
I had a job at a shop rewinding motors by hand and it costs a ton of money to get that done to a motor, usually more than the cost of a brand new one.... But if you go to a good rewinding shop they use nano-coat magnet wire that can be used with a VFD up to 2000HZ.....
How about seeing what a motor shop would charge to rewind it. If you payed $25.00 for it, you've got some headroom on cost,
and if it's the nicest grinder you have it might be worth it.
