- Oct 4, 2016
- 7,023
My project today, that is in "what I did today thread", caused me a problem. My OEM clutch Z bar had to be adjusted, with a relocated hole. I used my calculator for RPM used a 140* pilot, 3/8" CL shorty bit, and just polished the hole. If I'm going to burn a bit, I changed to a jobber Erwin. It screeched, and made all kinds of noise,I started just pulling hard, and then it just started cutting. I adjusted speed RPM up, and down from the calculated RPM, but I think the OEM steel is harder than what I was using as an input, and my machine will not run the RPM indicated 3056, ( if I calculated it right). Wondering what I was doing wrong...input......RPM....or bit type. Thank you
