Ken, thanks for the comments, but no I didn't rub so much that it rub the ink off the high spots, first I rub on the inkd area of the plate, then I place the part over an area of the plate that has no ink and rub it, which does like you say remove the ink from the highest points. the recommended time of rubbing of 20-30 seconds is really more for beginners, however now that I have progressed, I find that like you mentioned around 6 nice steady slow strokes is really all that it takes as long as you have the right amount of ink on the plate, and there is only one way to find out, it takes practice to get it all right. im still very much a novice, but I have had some very good instruction, I don't wanna take away from hobby machinist, I feel as tho its my home, but when it came to asking and learning about scraping, I went to PM to talk to Rich K, and to guys that scrape for a living.
I have spent countless hours scraping at the hobby level, like many of us here, we were lured to the finish, and then like a disease it takes over, and your scraping everything, making scrapers, making pull scrapers, and wow what a finish that pull scraper leaves. The most important thing I have learned so far about scraping has to do with reading the ink, that has got to be second to none, it determines if you are correcting geometry or if you are ruining it.
