My homemade pellet swage tools
I'm going to try my hand a making the carbide cutter. would you mind posting a few more pic of the cutter?
I will certainly get you some pics. Traveling at the moment but will be home tomorrow.
Nicely done, but I am going to ask a stupid question. Why are you not casting these? Or casting and doing a final swage?
In my research, casting did not provide the consistency that people had hoped for. I shied away just to avoid the heat. It does work and some do it. I think varying temps in the cavities from pour to pour creates varying dimensions and densities. Purely speculation on my part.
While the questions are flying, how consistent are your pellet weights with this system?
I fabbed a half inch square drive for the arbor press. By using a torque wrench in place of the leverage handle I am able to keep my swage pressure relatively consistent. Around 80 foot pounds on room temp lead.
Across 18 cavities, I have seen variances of around .2 of a grain on 15-16 grain projectiles BUT, and it’s a big but, I can sort by cavity if I’m feeling extraordinarily retentive and cut that value just a bit. Doesn’t show up much on the target tho. From a weight perspective (or any perspective for that matter) my projectiles are not more consistent than store bought within a given tin, but I have seen factory pellets vary between production lots. The NRE for this project far exceeds a lifetime supply of pellet purchases but I’m hoping it will be a fun introduction into reloading if the grandkids take interest.
Here is a couple pics of my .25 cal. It’s a 4 flute center cutting carbide. Although you do not plunge with this cutter, I think center cutting is necessary to achieve the dome. Again, I did not make these. I am convinced that the dark art of precision cutter grinding is a side hustle for Oompa Loompa’s. The guy who ground these always had a piece of chocolate with him.
Haha! That's hilarious. I'm gonna borrow that! Just replace "precision cutter grinding" with some other seemingly impossible to understand skill. Too funny.:encourage:
I'm eventually going to try to do this with a single-lip cutter. It'll be a lot easier to grind (as in, within my capabilities, which a 4-flute is not...) and should work for the limited life required. Time will tell...
GsT
Really liking this setup. I just came across an FX Impact M2 in .25 cal for a screaming deal and, while i cast slugs for my AF Texan .457, i think i need to make one of these to feed the Impact.
@Eyerelief can i ask for a copy of your drawing for the .25 cal end mill? I plan on slugging the barrel and getting my own dimensions but it would be nice to have a starting point.
Also, what are the dimensions of your cavity blocks? I like the looks of what you have done.
On a different but related note, have you seen the version of the cavity blocks that uses molten lead to fill the cavities instead of lead wire?
That design is very similar to the one you are using but has an additional top plate with a v-groove that the lead is poured into to fill the cavities before being replaced with the guide plate and final swaging of the pellets. I saw the video once and can't find it now or I would post a link.
Thanks,
Joe
Thanks,
Joe
No problem Joe, I would be happy to share. I'll dig it up and send you a pm. The dimensions of each half are 1.5"x1"x6", the guide plate on top is 1.5"x.75"x6", and the plate on the bottom is .5"x2"x6".
I have seen the version of the cavity blocks that are basically molds. I am sure they work well but since many precision pellet manufacturers are swaging in production, I got to believe that this process yields a more consistent projectile.
You could probably use my design to mold the pellets, but I think you would need to preheat the tool prior to use.
I think that if I were to entertain molding pellets, I would make a tool with only a couple of cavities and weld it to a pair of pliers to open and close. Similar to how bullet molds are made.
Sounds great.
The thing I found interesting was that the lead was poured into the cavities and then swaged. My concern with that process is the possibility of dimension changes due to thermal expansion.
I'll keep an eye out for those drawings.
Joe
Sounds great.
Joe
Already sent
I'll need to describe all of this process in a couple of different entry's, but I'll keep them all under this post. Let me apologize in advance for bouncing around a bit on this post, didn't give myself much time to gather my thoughts.
I built 4 different calibers of tooling, .177, .20, .22, .25. I need to state also that the basic tool is not my design, but it has been highly modified to suit my ideas, limitations and abilities. The punches, the actual design of the pellets (all diablo style but to my dimensions), the cutters, extrusion die for lead wire, and the lead wire cutting device are all my design, more on those later.
Here is the completed, assembled unit, the two rods sticking up are punches used for swaging the lead and shaping the back of the pellet:
Here they are removed. Note the left one is cupped. It is used to force a length of lead wire down into the cavity. The right one finishes the work and puts the cavity at the back of the pellet.
Here is the exploded pic. From top to bottom, left cavity, right cavity, base, top with guide holes for punches, 3 cavity assembly bolts, 2 punches:
Here is the custom ground 4 flute carbide cutter. There are several places online to get them, if you can provide them with enough detail. The further right of the dot you go, the more expensive they get ie .001 dimensions on your drawing cost a lot less than .00001.
And finally, here is a couple of pellets:
I am pleased the way they turned out, and they shoot well. You can see a faint parting line when blown up to this size, but they are almost non existent in reality.
The cavity halves and the top are made from precision ground A2. For me, it machines well and is plenty strong. Precision ground because I don't have a surface grinder. After I have drilled and tapped, installed the locating pins and cut the cavities, I assemble the two halves and stone the cavity opening sides flat by hand. I do this mostly because I don't have a surface grinder, but secondly because I want to remove an absolute minimum of material and I want a very fine finish. The setup for milling the cavities was pretty straight forward, I will cover that as well.
The base is made from 11L44, but any steel can be used. It provides a work surface and protects the pellets on the opposite side from where you are working. It is relieved between the pins so that the cavities can be turned over when you are making pellets 10 through 18. The relief is there so that you don't disturb the base of the pellets you made. The relief is in the top so that extruded lead has a place to escape during swaging. It about .200 deep. The holes are reamed just a shade undersized in the top so that I can roller burnish them into a great finish and a precision fit. I should also mention here that I use a No1 arbor press to push the punches down. I even made an adapter for the arbor press so that I have a half inch torque wrench for a handle so the operator knows when to stop pulling down.
The punches are made from 5/16" turned ground and polished rod, O1 I believe. The outside (fat part) is 12L14. The inner rod slides up and down inside the 12L14. The 12L14 provides a positive stop so that you get the exact same depth every time without over travel. My pellets stay within a few tenths of a grain.
When swaging, some lead extrudes past the punches. You want that, you need something to plane off when you are done if you want truly accurate pellets. After you have used both punches, the top lifts off and you use a razor sharp cutter to shave off the excess lead leaving a perfectly flat, smooth base on the pellet. For a razor, I use a hand planer blade. They are sharp when you buy them, but I stone them and then strop to a polished edge. Sharpness is key, if its not razor sharp, then the lead deforms during the planing operation. You can kind of see the polish on the blade but the light wasnt great. Its a mirror finish and scary sharp. After you plane off the first side, flip the tool over in the base and do side two (do a search on Youtube for HM HEN and you can see this basic design in action):
Although you can't change the shape of the pellet without making new tools and buying a new cutter, you can continue to change the second punch, experimenting with skirt thickness, depth of cavity, taper etc. This will also change the weight of the pellet. It seems to make a difference. I have found a great contour for one of the .177 pellet guns, but the other I am still working on for example. I will have a punch for each gun. I have a few old Sheridans, I hope I dont need a punch for each of them but if I do, so be it. Punches are cheap, a 3' stick of drill rod or turned, ground a polished cost a couple bucks and you are set for a lot of experimenting, roughly 17 -18 pieces at 2" each.
Let me also be clear on the fact that you could buy a box car full of factory pellets for what you will have in one of these tools. I think I have around $125-$150 in material alone, another $150 ish on the cutter (depends on the size of the cutter). The builds were slow, but quite enjoyable. The kids enjoy making their own, and I suspect my grandkids will as well.
I like the fact that it is a zero waste activity. I save old pellets, all my shavings and failed experiments. I melt them down in a lead melting pot, poor them in 1/2" x 2" round cavities. I save the ingots and when i get a few, I extrude them into lead wire with my 20 ton press. One ingot will extrude out to about an 18" wire 1/8" diameter. An 18" wire 1/8" will make about 30-35 .20 cal pellets. I'll get more into that later.
My wife tells me I have to BBQ a turkey tomorrow and I am sure that wont be all. I might not get back to this post with more pics till next week.
Wishing everyone on HM a Happy (and safe) Thanksgiving
Wonderful work. Is there any way I can get a set for .177 pellets. Happy to cover costs plus!
