been very busy with the lathe changing all the oils and cleaning out the oil galley on the carriage account of one hole was plugged with old oil. they where using oil so thick it wouldn't pressure feed through galleys without really pushing the plunger on the carriage . then the lead screw still had shipping grease (cosmolean) spelling wrong so dried out that i had to scrape it for a couple hours with screw running , must of never used threading on lathe . now i've run it through all it's paces and it works incredible .
i've upgrade some 4x4 transfer case rods for the early bronco community i belong to , so you can have front wheels or rear wheels engaged in high or low gear . the reason we mod them is if your slipping the front or rear wheels you can disengage them and put all the power where you need it .
