- Oct 16, 2019
- 6,570
I've been jonesing for a CNC router for a while now.
Two main criteria
1) it had to fit on a 2' x3' table...my welding table.
2) it had to be able to mill aluminum with decent results.
Looked at all the options from OpenBuilds, to Scienci to DIY.
On a DIY CNC Facebook group I ran across the PrintNC design. Scaleable, open source, (I'm a big proponent of open source), fully supported by a user/builder base.
https://threedesign.store/
The preferred system for the machine is LinuxCNC. I'm complete Linux noob let alone LinuxCNC. GRBL is another option but I wanted to go with the tried and true. I found a cheap used Dell desktop tonight and installed Linux and LinuxCNC.
Well I tried to...until I ran into a problem.
Remember that user base? One kind fellow walked me through command-line inputs to delete disk partitions like I was an old hand.
And it worked. I have the control PC all setup.
On to the building of the machine.
Two main criteria
