12bolts--if you have a scroll saw these are very easy to make. They are call french fitted drawers and the purple is flock. The procedure is as follows:
Layout the tools (I used 1/2" MDF with a 1/8" masonite bottom)
Allow for finger holds to get stuff out
Cut the shape out, you don't need to be accurate this is very forgiving process.
Slightly round the edges (1/8" quarter round router bit)
Glue the 1/8" bottom on
Paint with glue same color as flock (the one I used is called Wine)
literally dump the flock on heavy and allow the glue to dry
Turn upside down and knock off the excess for reuse
Your done--stand back and load up with tools.
For more info see the DonJer Website --
http://www.donjer.com Woodcraft sells the stuff as well as other websites.
If you don't have a scroll saw, a jig saw works or a coping saw. Craigslist has these scroll saws by the ton for about $50 bucks, buy one use it then sell it.
Holler with any questions.
