- Jan 28, 2022
- 10
More progress on the Nantong.
Have built a rotodyne converter and it's working great. Running the drill press and now the mill temporarily connected.
There is a problem with the wiring in the switch. Low speed works fine but not high speed. I've determined the motor uses delta connection on low
Double star on high speed. I finally get the motor to run on high I disconnected all the wires from the switch and went direct to the motor.
Success!!! This machine screams at top speed. 4800 RPM!! Where would a person ever need such speed?
So now I need the proper wiring diagram for the switch. I don't see any problem with the contacts. Went through all the contacts with a meter. Can actually see the contact move.
If anyone can help with the wiring diagram it would be much appreciated.
