[4]
Need a custom pin made
[3]
[10] Like what you see?
8mpg
Active Member
Sep 8, 2018
76
While trying to fix my first lathe...killed a pin that holds a large half pulley onto the drive spindle. Its for a Cazeneuve HBX 360 lathe and goes on the bottom variator. Im hoping someone can help me make a small part. Its only 1" long or so. Below is a drawing:
Doesnt need to be anything special as far as material I dont believe. If someone can help, please let me know. I'd gladly pay.
Tim
ttabbal
H-M Supporter - Silver Member
Jun 12, 2017
860
It might help if you gave some tolerance and the pitch of the 4mm thread, maybe the depth as well.. :)
rwm
Mar 25, 2013
1,603
Easy enough. But yes the tolerances would be important. How accurately do think you have measured this? Is the max OD really .250"?
On second thought, the part is probably metric if the screw threads are?
Robert
Yep, it French.
Robert
8mpg
Active Member
Sep 8, 2018
76
Im just measuring with a digital caliper. Tolerances arent THAT big of a deal. Smaller would be better. Within a few thousandths would be fine. The 4mm doesnt even have to be 4mm. I'll take an equivalent #6 or 8, whatever pitch. Its just a tapped hole to insert a bolt into to pull the pin out. Depth of the hole 1/4" would be great.
If needed, I can use a micrometer. Thanks for the help
Micrometer measurements: .245", .228", .156"
rwm
Mar 25, 2013
1,603
Looks like you have a taker on this. I was just asking because if the shaft is .001 larger than the hole, then it is a big deal. It's just so much easier when you can test fit on site. Making a part remotely is difficult unless the specifications are right on. Those micrometer measurements are a good idea.
Robert
8mpg
Active Member
Sep 8, 2018
76
If I have a minute or 2 tomorrow night I'll make one up . I can send it in an envelope for the price of a stamp .
Thank you so much! I can paypal you some money as a thank you
8mpg
Active Member
Sep 8, 2018
76
The measurements should be correct. The caliper vs micrometer was within .001 which should be plenty good.
mmcmdl
Staff member
Jan 31, 2016
1,437
Well , I just found out that it's a 13 hr night tonight . I'll get that pin made when I get a few minutes .
mmcmdl
Staff member
Jan 31, 2016
1,437
Other than the tapped hole , that pin is MADE ! LOL . Thats a tiny thing .
8mpg
Active Member
Sep 8, 2018
76
Pins done . Made out of a grade 8 bolt . Put a 6-32 thread in to save some of your wall thickness .
Thank you so much! I'll pm you my address. This is a great community.
[6]
[5] [7]
