T
Tom Griffin
Forum Guest
Register Today
Ed,
That a good quality mid-priced indicator, and a good value. The inexpensive imports might be a better choice for the home shop if you were looking for a dial indicator, but for a dial test indicator I would suggest you get the best you can afford. A dial test indicator like this is a delicate instrument and the cheap ones can be unreliable. If an indicator sticks, you won't know if it's giving you a true reading or not, which make it worse than worthless. I've worn out Enco's and Mitutoyo's, but still have and use all the Interapid's I've ever purchased. Also, the better indicators like Interapid are much tougher than the cheapies. I once saw one launched across the shop when the spindle in a mill was turned on with the indicator in it. The poor thing smashed against a wall, but came out totally unscathed. Try that with a cheap import. :yikes:
Tom
Tom
