Need help deciding between PM-1440GT and PM-1340GT
neigy
Jun 24, 2018
3
It seems that the 1440GT has a slightly larger Spindle Bore, and a slightly longer spindle length, and can spin a 14" stock as opposed to 13" of stock over bed, uses D1-5 Camlock instead of D1-4 Camlock, it is a few hundred pounds heavier which can add to rigidity, but other than that I'm not seeing anything else which distinguishes the 1440GT from the 1340GT to really justify the price difference of $3,000.
Am I missing something? There has to be a reason that I'm overlooking which puts the 1440GT in a class of its own...But what?
Thoughts?
Winegrower
H-M Supporter - Gold Member
Jul 29, 2014
761
I have a 10” Logan, a nice lathe, and volunteer at the local railroad museum, where I use a 16” Monarch. I realize that bigger is not really better...so much harder to even move the tailstock left and right, or reaching around the four jaw chuck to use the two key technique. And chuck changes...forget it!
We are getting a 24” LeBlond. Wow! But some of these rail wheels need to be trued up occasionally, so there is a reason to go bigger.
For home use, I realize that 13” to 14” is not that dramatic, but unless I had some clear need for a bigger swing, I would save the money. Really, 10” covers 99.95% of my personal stuff.
mksj
Jun 12, 2014
2,638
This has been previously covered in several postings.
https://www.hobby-machinist.com/threads/1340gt-1440gt.67669/#post-566185
https://www.hobby-machinist.com/threads/pm-1340gt-vs-pm-1440gt.46442/
It is not necessarily just looking at the dimensions, but everything adds up. I have a 1340GT, and it is a very nice lathe, but at times it would be nicer to have a heavier lathe to take deeper cuts, or have a larger spindle bore, as 2" in this size machine is very uncommon. If I added a cast iron base to mine larger motor, etc. it would quickly add up to the cost of the 1440GT. If I wanted to go bigger I would get a RML-1440 at 2X the price and over 2X the weight. It all boils down to what you will be doing and the budget. A heavier machine will be much more rigid
benmychree
John York
Jun 7, 2013
4,825
You can do smaller work in a larger lathe, but not vice versa; personally, I use a 19" swing lathe for most all the work that I do, but do appreciate a small lathe for small work, and also have a 9" Monarch.
Asm109
Aug 29, 2017
296
I think you will find that D1-4 spindle mounts are waaaaaay more common than D1-5. So your used pickens will be better with the 13 inch lathe.
pacifica
RGL
Jan 2, 2018
305
I had the same conflict,but went with a 1340gt, I felt price difference was substantial.
When you add a quality collet chuck, VFD, gates belt, machined sheaves, toolholders w. inserts, well that is another $2k plus.
Neither of these lathes are super heavy duty like a clausing colchester, mori seiki but fit a price niche and can do quality ten thousands inch tolerance work,out of the box(crate)and are new with proven support.
Boxster9
H-M Lifetime Diamond Member
Jan 21, 2016
30
First, they are both great machines for hobbyist work. Second, what do you see as your future needs for this lathe? Is weight, Spindle Bore, D1-5 Camlock important to you? I personally went with the 1440 GT as someone in this post said, "buy once, cry once." I am glad I made the purchase of the larger machine with greater flexibility and expansion of my needs. Not had much need for the larger swing (yet), but the power and stability is a joy along with the larger Spindle Bore. Enjoy whichever machine you choose, Matt and crew at Precision Mathew are great people to deal with and help you make the right decision for you.
Silverbullet
May 4, 2015
3,579
I've always tried to tell newbies go as big as you can afford, it saves in the end so many times there back saying my machines not big or strong or long enough. So do yourself the favor go big , get the extras in a year or so after you know the machine. Doing some work can pay the difference or buy the extras everyone has to have. I don't know how I've lived without dros but I've done tons of machining without them for forty years.
jbolt
Dec 3, 2013
1,644
I don't think you would be disappointed with either one.
I went with the PM-1440GT because I wanted the larger spindle bore, larger swing, D1-5 spindle nose, enclosed gearbox, foot brake, pull out chip pan and coolant system. Mine is one of the first made and at that time it was priced $1,000 less than it is now so it was a little easier to justify the cost difference.
Don't be put off by the D1-5 spindle. There are plenty of chucks to choose from that can be had with that configuration. It is a significant step up from the D1-4 which I had on my previous lathe.
Now having used a lathe with a 2" spindle bore I would not want to go without.
The only quirk to the PM-1440GT is the spindle taper is not a standard taper. PM calls is a MT5-1/2 which isn't standard. They do provide an adapter to use a center. The only thing it really affects is if you want to get a collet closer. I believe PM has them or you can have one made to order from JFK Precision.
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
2,960
I just saw this post, Mr. Winegrower’s Monarch lathe in the Nevada City Museum is a great Machine. I recently toured the museum. The guys back in the shop were gracious enough to show me around. The Bridgeport is an old friend.
I asked, “when I retire, how do I volunteer here?”. I was told to, just come around, we will put you to work.
Their shop made forge is on my to do list.
petertha
Jan 15, 2016
834
I don't quite get what you mean. Doesn't a particular camlock designation like D1-4 or D1-5 define the spindle nose taper dimensions on that basis alone?
http://www.tools-n-gizmos.com/specs/Lathe_Spindle_Mount.html
ddickey
Apr 21, 2016
2,564
He's talking about the taper not the mounting system.
petertha
Jan 15, 2016
834
The spindle nose taper is an integral part of the mounting system. They go hand in hand don't they?
mksj
Jun 12, 2014
2,638
There is the nose taper which is specific to the mounting system, but that protrudes out. There is also an internal spindle taper for mounting collet systems, mounting test bars, dead centers, etc. Typically on this size machine it is a MT5, but this is usually with a 1 5/8" bore, I assume the large MT 5 1/2 is to accommodate the large spindle bore.
petertha
Jan 15, 2016
834
Ah - by 'the taper' we are taking the INTERNAL spindle taper. Gotcha.
jbolt
Dec 3, 2013
1,644
If you look at the specs for a D1-5 nose and a MT6 taper the spindle nose boss would get a bit thin. It's interesting that PM's Chinese 1440 lathes with 2" spindle bore and D1-5 nose have MT6 spindle tapers. Could be that the Taiwan manufacturers spindle cam lock system wouldn't work with a larger MT6 taper or they felt is sacrificed too much rigidity in the spindle?
zjtr10
May 5, 2016
72
Okay, thanks to you folks encouragement I'll go with the 1440GT.
Does PM ever have Columbus Day sales, Black Friday sales or something similar? Or is the list price what I'll have to pay?
jbolt
Dec 3, 2013
1,644
I believe on the premium machines he keeps the cost as low as he can. Sometimes he "may" offer a discount on accessories at the time of sale. Never hurts to ask but I'm guessing the current tariffs are not helping.
bill70j
Nov 9, 2015
225
zjtr10:
As Jay says, it never hurts to ask.
But what I do know is that Matt gave me a discount for paying cash for my 1440GT (wire transfer of funds) rather than using a credit card, for which he is charged a fee.
Bill
ddickey
Apr 21, 2016
2,564
Correct me if I'm wrong but I believe there are no tariffs on Taiwan made machines.
mksj
Jun 12, 2014
2,638
Currently no tariffs on Taiwanese machines, which makes them closer in price to the some of the Chinese offerings in the same class. Matt/QMT offers a lot of products (like Bison/TMX, Aloris, Vertex, Align power feeds, etc.) not listed on their website so it pays to ask. You also save on shipping if items are shipped with the machine.
Nice choice on the 1440GT.
ddickey
Apr 21, 2016
2,564
Also the sweet lathes made by Sun Master.
jbolt
Dec 3, 2013
1,644
I meant in a general sense since he does sell a lot of Chinese made machines, the tariffs would have an overall affect on the businesses bottom line which would make it tougher to offer discounts.
mksj
Jun 12, 2014
2,638
I have one on order through QMT (Matt), SunMaster takes lathes to a whole new level. My friend has the SunMaster RML-1640, and it is a a beast. Had an opportunity to sell my 1340GT, so I have the ERL-1340 on order. Should be very rigid, the RML series is even more stout. I was looking for a bit more rigidity coming from the 1340GT, but it was a great lathe at the price point. If you can afford to go bigger and/or heavier, worth the additional expense.
Working out the control/VFD system, I recently picked up a 3Hp Vector motor to replace the stock one. I typically reduce the pulley size and run the motors to 120Hz, which improves the motor performance dynamics. This also applies to the 1340/1440GT machines, although the stock 3 phase motor are quite good. Also, one is very limited motor size wise that will fit if you choose to upgrade. I typically use the Hitachi WJ200 VFDs on 1340/1440GT's, but I may end up using a Yaskawa VFD because it is not as deep and should fit in the stock ERL lathe cabinet.
Janderso
Jeff Anderson
Mar 26, 2018
2,960
Where/How do you look at/order a Sun Master?
Matt is a distributor?
wrmiller
Chief Tinkerer
Mar 21, 2013
3,764
Hmmm... RML 1440V. I don't need that much lathe, but I wouldn't kick it out of the shop because of that. :D
AdBlock Detected
I've Disabled AdBlock
