Hello everyone,
A good reason to post and say Hi. I need to lift my lathe off my gooseneck trailer and place it.
My lathe is a South bend 14 1/2" with a 8' bed, 6' center to center. Carriage and motor is still
on it. Everything else is off. The equipment I used to load it could lift 3 of them at a time.
But where it is now going is dirt and using a farm tractor to lift, pull trailer out from under
and carry 15' thru door and set on dolly's. Tractor forks are rated for 2700lb full height. I
will be lifting max 6' and get close to the base of the forks. Both other times I moved it the
machines were way oversized, this one is closer to what it can handle.
I know some of you have moved a little to a lot of these so any help would be great.
I wish I could just call the lady that worked in parts for South Bend almost forever but she
is now gone and we all miss her.
Thank You everyone,
Take Care,
Rick
Thank You everyone,
Take Care,
Rick
