- Nov 27, 2012
- 7,857
I like the freezer idea. Maybe a touch of heat then freezer? I don't understand the channel lock idea. It's off the spindle of course but I think I'm missing something here
Can try either or but don't think both is necessary consecutively. Wouldn't hurt to try I guess. Just throwing an idea out there.
I don't have a Unimat chuck but I do have some import micro chucks that all work the same. On a couple of mine the body extends out the rear. Clamp that in the vise, then turn the ring with pliers.
Or if yours doesn't extend out the rear like my other 2, clamp the ring in the vise & turn the body with pliers.
Again this would be an absolute last resort for me. If there's something that is causing it to bind rather than just actually being very tight, this 200 lb gorilla method may do more harm than good.
(Just took quick pics as examples, again I'd use padding to proect the chuck surfaces if I'd actually resorted to this, avoid if possible)
