- May 26, 2014
- 183
I want to motorize the crank on my Maximat V10-P lathe/mill. My thinking is to replace the large crank at the top of the mill column
or perhaps modify to add a gear below it then power it with motor to raise and lower the head then use the handle on the side of the head to make the final adjustment. There are a couple bolts on the left side that I'm sure I could mount a motor to and replace the bolts with longer ones. I would just need to know what size and type of motor I would need. I will have to run a speed pot and a reversible low rpm motor. Any suggestions would be welcome.
![100_4002[1].JPG 100_4002[1].JPG](https://www.hobby-machinist.com/data/attachments/69/69131-4e8688ca04faaf766a0c99f5b9cff754.jpg)
