- Jan 22, 2014
- 160
I am cleaning up a 3 jaw Union chuck and found it has a broken tooth on one of the jaws.
I'm between silver soldering the tooth back on or building up a tooth with some nickel rod
with the arc welder. What's the best way to fix this? Looking for opinions, thanks.
Don't try hard soldering because you need red heat to get the solder to flow. The jaws are hardened,you will anneal the jaw if you try hard soldering.Try an epoxy like JB weld.I wouldn't count on it holding forever but its worth a try. Otherwise use it like it is or as other posts mentioned soft jaws.Now it may be possible to soft solder the tooth. I have used regular plumbers solder and the correct flux,can't remember if it acid or rosin core. I never tried it on a chuck jaw but have had success making small tools that had a soldered joint. I pickled the parts in hydrocloric acid first. Then washed and scrubbed the parts with water. Fluxed the joint and heated the parts til the soft solder ran.Vinegar also works for a pickleing but takes longer.You won't lose the temper if you soft solder.
mike
