- Jul 23, 2014
- 347
I was thinking of gluing a printout of the pattern to the part. If I can make one good part I should be able to jig something up to use it as a pattern. I am a former carpenter and can probably get it pretty close but I'd like to get within .005 and that is probably out of my eyeball capability.
I meant glue the pattern to the fixture stock so you can located the indexing hole. Or very carefully lay out the pin position 18 degrees off of "12 o'clock". Every time you machine a "groove", you pull the pin and turn your part so the fresh cut is aligned by the pin. Should be pretty accurate.
