The holes will need to match up to holes in a larger piece of steel. I will drill those holes as well. I would consider true position to be the most important consideration with parallelism being a close second. If I match the two pieces from the sides I START the holes, that could account for a slight bit off on parallelism. Can't miss it by much, admittedly, but it should work.When you state " needs to be very accurate " , regarding diameter , true position , parallelism ? All of the above ?
Regards,
Terry
