- Jan 23, 2011
- 246
What is this some sort of speed governing system?
How did you know that .It is a governor off a Disston 2 man chainsaw. It has a 2 cylinder Mercury engine on it. REAL big Chainsaw
392F-68F=324F so…324 X 0.0000072=0.00233” so…gear heated up will be .465+.0023=.”4673” or thereabouts.Cooling the shaft in dry ice will shrink the diameter to .4685". Heating the gear to 200ºC will increase the diameter to .466" so you still have an interference. Shrink fitting parts require the parts are a slip fit at assembly. Otherwise heat transfer will normalize the parts and the attempt will fail.
So in a word, the answer is no.
The easiest solution would be to modify the gear as machining the shaft will require recutting the Woodruff keyway. For .004", you may have that much clearance in the key seat though. I see that the shaft has been brazed. More than likely, it wasn't heat treated afterwards. You might be able to reduce the shaft diameter enough for a fit. As Cadillac said, it shouldn't be a press fit. A heavy slip fit at most.
That's .00233"/". The gear has a bore of .465" so the change is .00233*.465 =.00108". The bore would increase to .4661"392F-68F=324F so…324 X 0.0000072=0.00233” so…gear heated up will be .465+.0023=.”4673” or thereabouts.
A crazy solution, then: I'd pull out a rat-tail file and try to take .002 off the interior radius of that gear. It's not precision youWellI I got out the micrometers and bore gauges and checked it out . it was worse than .004. I will be more than happy to send it to you and you can Measure it and then install it. This thing is CRAZY I know
Concentricity is a number. Careful draw-filing to .002 depth will have a couple of hundred microinches ofRiiiight. Concentricity between shaft and gear teeth is un important.
