[4]
New 12z Owner Here
[3]
[10] Like what you see?
Chris Bettis
Active Member
Oct 23, 2015
214
Well i figured id start a new thread.
Before I get into details. A little about myself, I went to school for precesion machine tool at warren tech. I spent 2.5 years there learning everything from basic manual mills, lathes, and surface grinders to edm machines, cnc machines, and even a breif crash course in plastic injection molding. I was taught everything I know by an old school master tool and die maker. Since then I've worked in the industry as a cnc operator in a production shop.
However I soon discovered the best way to kill a good hobby is to make it your job.
Ok actually production cnc gets extremely repetitive and boring. I fell asleep and got canned.
Went into automotive machining and eventually became a mechanic. Ive been in automotive for about 10 years now.
A few years ago I purchased a harbor freight 8x12 (14) lathe at a swap meet to support my other hobby, road racing. I've been wanting a mill ever since. But old iron is limited and expensive here in Colorado.
So i began looking into what started as the harbor freight round column rf45 clone. That eventually snowballed into a drastically reduced tooling budget and more machine. I stumbled upon a charter oak 12z mill. After moderate research I chose the 12z and placed a deposit. I ordered the machine while out of stock back on october 1st. Paul did give me a discount due to the item being out of stock.
Due to unfortunate shipping problems to no fault of charter oak I'm expecting to get my new mill late November but more likely early December. So you can expect to see some pictures in the coming months. But ill say right now not expecting to make chips right away. This was the absolute top of my budget and there isn't much of anything left for tooling right now.
After I recover from buying the mill ill be buying tooling to go with it.
Stay tuned for updates!
Sent from my LG-LS980 using Tapatalk
Franko
Feb 24, 2015
1,345
Waiting for months due to unfortunate shipping problems is just part of getting machinery, Chris. Welcome to the forum.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
Chris, it was a pleasure meeting you and yakking the afternoon away. :)
Looking forward to your impressions and progress reports after receiving your new toy. You mentioned that you built your stand a bit taller than mine. Are you going to shorten it or just try it first and see how it works for you? You're about 6'4" IIRC.
maker of things
Hermit
Jul 23, 2014
347
Ah yes, the waiting game. A confusing mix of excitement and frustration. Welcome to the club!
Don't forget to put up a pic of the stand you built, we all like pictures.
Chris Bettis
Active Member
Oct 23, 2015
214
Yes definetly I look forward to doing it again sometime! For the stand im going to leave it as is for now. And see how it goes. Worst case I will take the casters off and lower it down via the leveling feet. That should get me around 35 inches from the floor. And yes of course there will be many pictures and progress reports along the way.
Chris Bettis
Active Member
Oct 23, 2015
214
Yeah definetly a confusing muxture of excitement frustration anxiety etc etc.
Here in a couple hours i can put up some pictures it is not done yet though ill work on finishing it this weekend.
coolidge
Dec 18, 2013
2,005
That stand height looks like it could be fine, maybe 8 inches higher than my old stand which was too low for me and I'm 5'7". Design wise the 12z weighs a 1/2 ton and those leveling pads are way out to the sides, could be a bit springy but it looks like you used pretty thick tubing. My Kubota tractor front end loader lifted my G4003G lathe up onto its stand without any problem, but it couldn't budge the 12z more than 3 inches off the pallet its that heavy.
Chris Bettis
Active Member
Oct 23, 2015
214
Looks robust. :)
Thanks. The table of the stand is built from 2"x3" 11 gauge rectangle tubing. The legs and lower frame are 2" 11 gauge square tubing. Caster plates are made from 1/4" plate and the mounts for the leveling feet are made from 4" long sections of 2" square tubing ( scrap from the legs) it was cut at an angle length wise and 1/4 plate was welded to the bottom.
Initially I was going to copy charter oaks design for the leveling feet. But decided to take a different approach.
Charter oaks design places all of the load on the welded nut inside the down tubes something that is not serviceable. This design I came up with places the load on the leveling foot and lower nut. All serviceable parts.
Btw bill,
11/10/15 happy birthday.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
Yea, the 'spec sheet brigade' here will tell you the mill weighs less than 800 lbs., but they've not even touched one. Shipping weight on mine with the stand strapped to the top was around 1200 lbs. And I could press the stand over my head no problem, even for an Old Guy. ;)
You've seen my mill. It ain't no slouch.
Chris Bettis
Active Member
Oct 23, 2015
214
For your veiwing pleasure and just a tad bit of gloat this is my office. a360fffe2f5dbc4749b581b6f3439665.jpg
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
Yea, yea... First you have to tell me about this, and then you post pics? Thanks dude. ;)
:you suck:
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
BTW, didn't tell you I twisted wrenches for a few years. All the ASE certs, and Master level on MB and LR. Didn't bother with the Porsche certs as I hated working on those little things with these big paws... :(
Chris Bettis
Active Member
Oct 23, 2015
214
No you didn't mention it. And actually I don't have any ase certs I always worked in dealers before this job so I got factory certs instead. Now I work in fleet maintenance for a private company so it's not required.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
I was told it couldn't be done, so I took all of the tests for the basic ASE certs at one time. Passed them all. :)
Last dealer I worked at carried Mercedes, Land Rover, and Porsche. My stainless tool boxes and work benches were built into the wall. Compressed air, oil, and water hoses came down from the ceiling between my two lifts. Brick floors that we had to scrub every week. The owner had a lot of money in that dealership. :eek:
But twisting wrenches is a young mans game.
Chris Bettis
Active Member
Oct 23, 2015
214
Yeah that's bs, at least it is these days. Ase anymore is for independent repair shops so customers will feel comfortable there all the manufacturers have their own training programs some will even send you to fancy schools like wyo tech etc for free. Then have you sign a contract stating they basically own you for 5 yrs.
Chris Bettis
Active Member
Oct 23, 2015
214
This is a couple pictures of some other equipment in my home shop. Jd2 model 32 hydro tubing bender9e573883c8ed3db3e24b629627ccfccf.jpg0300f7636e4cad7010aea7ad67ef4b98.jpg3d595c6f6c91d31de1967bd9b936fd05.jpg3f126664db6f815b5802fbe97e44ef91.jpg16e855fc182e56b62a99385af5585463.jpg
The base of the stand is also custom built, it is 1" square tube welded with casters and 1/2" bolts coming up to level the upper portion of the stand it is hydraulic so all bending forces are contained in the frame of the bender. This lets me have it mobile so i can pull it out in the driveway bend a tube, then put it away in the corner instead of bolting to the floor in a fixed location.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
Where were you when I needed a roll cage for my RX-7? ;)
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
Mid to late '90s is when I raced Solo-I.
Chris Bettis
Active Member
Oct 23, 2015
214
Yeah I believe I was in elementary or middle school then. Back in the days of flux core mig welders electrical conduit and goped motorized go karts.
Too many ideas too stupid to know better. As a kid I put a 5hp briggs on a big wheel scooter from wal mart. The sprocket mount was an old skill saw blade welded to a driveshaft. Yeah I shoulda died a few times..
wrmiller
Chief Tinkerer
Mar 21, 2013
3,507
Yea OK, so I'm old. :p
I told you about the go-cart with the Honda 450 twin and no brakes. Sometimes I wonder how I managed to still be here... :eek:
Chris Bettis
Active Member
Oct 23, 2015
214
Haha yeah I plan to build something similar but with brakes. Have to buy a garage and chassis table first
[6]
[5] [7]
